I know its a pretty common project. But im looking at decking out a rc truck with police lights. Ive been looking through the forums and have found alot of usefull stuff. Everything ive found though is for 9VDC. Ill be running theese off of a 3 cell LI-Po battery. its max voltage is 12.5VDC with minimal voltage of 11.1. 500MAH capacity with a 20C-35C Discharge rate. So it has a max output of 17.5 amps @12Volts.
The project has 4 key compents,
2 red/blue light bars w/10 LED's each
Front headlights, 2 LED's each- white
Rear taillights, 2 LED's Each- red
Each Light set Needs to have two alternating sequences.
Ive included basic layout of the sequences im looking for.
The info i need help on is,
componets- this is where i really lack in knowledge.
Wiring Schematic
Any help is greatly appreciated. Thanks
Wiring Schematic
