| Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help. |
Thread Tools | Display Modes |
#1
How do you know whether it is leading or lagging in Power Factor?
![]() ![]() I was told by my lecturer that if the sin θ is positive then it is lagging And if it is sin θ is negative then it is leading However, in this case, the answers that I got is all positive but it has a variation of leading and lagging. I am confused. Does he means that if the θ is positive then is is lagging and if it is negative then it is leading ? I try to google up on this and this is what I get ... But I practically do not understand a thing from the Mnemonics From the Mnemonics "ELI the ICE man" or "ELI on ICE" – the voltage E leads the current I in an inductor L, the current leads the voltage in a capacitor C. CIVIL – in a Capacitor the I (current) leads Voltage, Voltage leads I (current) in an inductor L. P/s: I have also upload the solution if you need more detail on the solutions. |
#2
You calculated cos() and not sin().
Another way to find it is to look at the angle of the current relative to the angle of the voltage. If the currents leads the voltage (greater angle than voltage) then the power factor is leading (capacitive load). If the current lags the voltage (less angle than voltage) then the power factor is lagging (inductive load).
__________________
>> Troubleshooting is an art << http://www.youtube.com/watch?v=hC7KYbFBPHA http://www.youtube.com/watch?v=StNJlRTWs9k http://www.youtube.com/watch?v=j-4h3l9O4fc http://www.youtube.com/watch?v=E0jZJ...eature=related |
#3
If the resulting current phase angle is more negative in relation to the driving (source) voltage phase angle, then the power factor is said to be "lagging".
If the resulting current phase angle is more positive in relation to the driving (source) voltage phase angle, then the power factor is said to be "leading". So if the driving voltage phase angle is If If Then if The driving (source) voltage phase is often assumed to be zero (for convenience) and in that situation it is immediately obvious that a lagging power factor condition is indicated by a negative sign for the current phase angle. Similarly a positive sign for the current phase angle indicates a leading power factor. |
#4
That should read
If |
#5
Thanks for the explanation ! I understand it nw XD
#6
Thanks for clarification. Is it safe to say that constant 240V = 240<0 V (phasor)
#7
Yes it is.
__________________
| Tags |
| factor, lagging, leading, power |
Related Site Pages
| Section | Title | |||
| Textbook | Credits : Contributor List | |||
| Textbook | Selsyn (synchro) motors : Ac Motors | |||
| Worksheet | AC power | |||
| Worksheet | Phasor mathematics | |||
| Worksheet | Trigonometry for AC circuits | |||
| Worksheet | Impedance | |||
| Worksheet | AC phase | |||
| Textbook | Synchronous Motors : Ac Motors | |||
| Textbook | Harmonics in polyphase power systems : Polyphase Ac Circuits | |||
| Textbook | Calculating power factor : Power Factor | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| leading or lagging power factor | fancy102 | The Projects Forum | 9 | 01-07-2010 08:56 AM |
| E-book Correction Error in Maximum Power Transfer Theorem page | Ray A. Rayburn | Feedback and Suggestions | 27 | 09-01-2009 08:53 PM |
| Subsea Power Distribution | Screamtruth | General Electronics Chat | 1 | 01-19-2009 01:30 PM |
| Lagging or Leading Power Factor | ha4nguyen | Homework Help | 4 | 03-06-2008 05:49 PM |
| Thread Tools | |
| Display Modes | |
