| Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help. |
Thread Tools | Display Modes |
#1
Hi guys... new here I have a problem with the following and hope all the gurus here can help me out on this Consider a transmission system using Cyclic Redundancy Check (CRC) technique with a generator polynomial 10101. The receiver receives the following bit pattern: 100111011000. (a) Draw a digital logic circuit for a shift register implementation of CRC. [12 marks][8 marks] (b) Use the logic to evaluate the received bit pattern to see whether the bit pattern is error-free. thank! ![]() |
#2
There are a number of very good articles on the Internet that present a solution that uses gates. Here is a pretty thorough article on CRC that covers the subject.
hgmjr |
#3
thanks for the link hgmjr!so base on that article 10101 = 1*x0 + 0*x1 + 1*x2 + 0*x3 +1*x4 therefore = 1 + x2 + x4 but is the circuit like this? A<---B + C<---D + ![]()
#4
Please help to see if this is correct becoz the 12 mark question is ok for me... juz need to get the circuit right... pls?
#5
Go ahead and take a stab at drawing up the CRC circuit and post it here. We can then make suggestions on what you need to adjust should a correction be needed.
hgmjr
__________________
"No human being should be allowed to have this much fun." hgmjr May we never lose compassion for those who need our help and encouragement.
#7
here you go...
#9
i look at my coure notes and they only have A B C D for 5 bit 11001
and this is how they drew it can you kindly enlighten me directly??... i am really confused now ![]() ![]() thanks... |
#10
I stand corrected.
You wrote the correct equation in your earlier post. I am used to the flow shown like the article that I linked you to earlier. One thing for sure, your vertical arrows should be pointing into the circled + signs rather than the flip/flops. hgmjr |
| Tags |
| crc, implementation, register, shift |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Problem: Transmitting Between Two Shift Registers | Ryan_1700 | Homework Help | 4 | 04-14-2009 10:14 PM |
| About a a Non-OS dac with the shift register | gaetan8888 | The Projects Forum | 1 | 12-26-2008 06:49 PM |
| Shift register | Gween-fwaker | General Electronics Chat | 2 | 09-05-2008 09:33 PM |
| decoder and register in Verilog | notwist | Programmer's Corner | 1 | 11-22-2007 04:44 PM |
| Serial In/Serial Out shift register | MWalden | General Electronics Chat | 3 | 06-09-2007 07:30 PM |
| Thread Tools | |
| Display Modes | |
