| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
On the main page there is a formula which shows that the frequency cut-off (0.707) is found from 1/2*Pi*RC. But why?
Thx in advance |
#2
Well If you are talking about an AC component under AC conditions then the formula for the Capacitive Reactance is:
XC = 1/2π f C, Im not sure which example you are talking about, but I'll go on anyway. If we are going to make the Resistance (R) which is in Parallel with Capacitor C, then the formula becomes; XC = 1/2π f C = R, then to determine the frequency f the formula is transposed to give; f = 1/2πRC, Think of it like this, as XC = R the voltages across each component will be equal, plotting this out on a Phasor diagram will show that the angle of VR and VC are 45 degrees , therefore the voltage VR is equal to Vin cos(45) =Vin/(root2) which is 0.707. Basically you need to draw phasor diagrams, using complex numbers will help. Nirvana. |
#3
plz explain
i have never seen the formula for calculating cut-off, instead just know abt it tht it is the breakdown voltage for transistor , MOSFET . can u plz explain again tht why it is cut off at 0.7 why not more or less than tht |
#4
Cutoff frequency and breakdown voltage are two entirely different things. Can we backup for a moment and decide which one we are talking about.
BTW are you aware of the following: |
#5
me tink it was 0.7071 wen i were in school a long time ago, look it up in a sine table[ 4 fig ] to reveal the hidden angle or inverse sine on a calculator, if i remember rightly we were fiddling with rms value
#6
yes man i m aware of tht
so wt would u sat abt cut off |
| Tags |
| cutoff, frequency |
Related Site Pages
| Section | Title | |||
| Worksheet | Signal modulation | |||
| Worksheet | Class C BJT amplifiers | |||
| Textbook | Tesla polyphase induction motors : Ac Motors | |||
| Worksheet | Passive filter circuits | |||
| Textbook | Frequency and phase measurement : Ac Metering Circuits | |||
| Textbook | AC voltmeters and ammeters : Ac Metering Circuits | |||
| Video Lecture | Op Amp Applications - Active Filters - Op Amps and Op Amp Circuits | |||
| Video Lecture | Sine Wave Characteristics - Alternating Current | |||
| Textbook | BJT quirks : Bipolar Junction Transistors | |||
| Textbook | Measurements of AC magnitude : Basic Ac Theory | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| HOW is Frequency Altered in a Circuit? | quicksilver | General Electronics Chat | 3 | 07-03-2008 01:04 AM |
| Low frequency LFO with a DVM meter? | relicmarks | General Electronics Chat | 14 | 05-03-2008 06:50 PM |
| frequency analyzer or spectrum analyzer troubleshotting | relicmarks | General Electronics Chat | 25 | 04-28-2008 08:18 AM |
| How to implement an Upper Cut Off Frequency? | Denny1234 | Homework Help | 4 | 04-18-2008 01:50 PM |
| Frequency modulation | Dpetervan | Radio and Communications | 6 | 02-26-2007 11:51 PM |
| Thread Tools | |
| Display Modes | |
