Not sure what you're looking for exactly, but this is a fairly basic power supply circuit. With such a low current a linear regulator is a pretty good choice, though you will probably want to heat sink the regulator chip.
Bridges can be either bought as components, or built using discrete diodes.
If I wanted to adapt this configuration to a different output voltage, how would I calculate the change in components? If I wanted to change the output to 3v dc, would simply changing the voltage regulator to 7803 do the trick?
I don't mean to ask stupid questions... I just don't have the electronics background to complete a project.
I found this second drawing on another site. It's very similar to the circuit posted by Bill Marsden. Bill's uses a 100μF capacitor and the other uses a 50μF and a 0.1μF in parallel.
Is there any advantage or limitation to either design? Do both do the job equally well?
Bill's Circuit
New Drawing
Also, This drawing shows the 50μF at 35v. I keep finding 25v and 50v capacitors, but no 35v. Would a 50μF 50v work?
