All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-24-2009, 03:58 AM
frenchie29 frenchie29 is offline
Default difference between potentiometer A and B
I totally forgot about that one
What's the difference between potentiometer type A and B?
And the one that's the most used for audio?
  #2
Old 04-24-2009, 06:37 AM
bertus's Avatar
bertus bertus is offline
Super Moderator
Default
Do you mean the diffrence between linear and logaritmic potentiometers?
Here is a link called "The Secret Life of Pots", with a lot of information on potentiometers.
http://www.geofex.com/Article_Folder...s/potscret.htm
The link comes from the EDUCYPEDIA on Resistor technology.
http://www.educypedia.be/electronics/resistors.htm
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #3
Old 04-25-2009, 12:11 AM
Default
There's no mentioning of A or B type!! Unless I didn't see it. I remember well A=audio taper log. But I am not sure anymore.
  #4
Old 04-25-2009, 12:25 AM
Default
I need to replace that trim pot for this project
http://www.kitsrus.com/pdf/k17.pdf
  #5
Old 04-25-2009, 12:28 AM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
That's a log pot. You could use an audio taper pot.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #6
Old 04-25-2009, 01:00 AM
Default
So type A??? The thing is that trimpot that came with that kit says 10KB on it. That's why I'm a bit confused. Also I want to use a TRS female connector for the audio input.
Tip to audio in
Ring to audio in
Sleeve to ground audio
Is that right?
Quote:
  #7
Old 04-25-2009, 02:06 AM
Darren Holdstock Darren Holdstock is offline
Default
I don't recall ever seeing a log trim pot - they seem to have specified a log pot in the schematic, but supplied a linear pot with the kit. It won't matter if you're just using the pot to set the gain just the once, it's only if it's being used as a working volume control that it might become annoying as the relationship between pot rotation and perceived loudness is non-linear with a linear pot.
An old trick to make a lin pot a bit more loggy is to add a resistor from wiper to ground - it quite often makes a more repeatable pot, as log pots are very hard to make accurately, and the tracking between dual log pots can be poor. Bertus' link (above) explains more about this technique.
  #8
Old 04-25-2009, 02:30 AM
Default
I have both 10k A&B 25kB and 50k audio log (A) Now I know that the A type is for audio it says it on the 50k pot Which one would work best? I don't really want to use the 50k they cost me like $5 each
  #9
Old 04-25-2009, 03:01 PM
SgtWookie's Avatar
Expert Member
Default
You need to use a 10k Ohm pot, otherwise you will have an impedance mismatch. Line-level audio is designed for 10k Ohm impedance. Using an incorrect resistance pot may result in distortion.
If you use an audio taper pot but install it backwards, it will seem like you have almost no control over the volume for most of the pot's travel; the volume will suddenly go from almost nothing to almost full blast. If that's the case, you'll need to swap the two outside leads on the pot.
The center lead is the wiper; it must be connected to the input of the amplifier IC.
__________________
General info:
  #10
Old 04-25-2009, 03:54 PM
Default
I think I have the wiring right I used a 10k pot. The thing is, when the pot is barely open I get major distortion then when I turn it clockwise it gets cleaner and the volume increases. Is the distortion cause by not enough audio signal? That's weird I've never heard that before.
Tags
Related Site Pages
Section Title
Worksheet Digital-to-Analog conversion
Worksheet Phase-locked loops
Worksheet Four-channel audio mixer
Worksheet Potentiometers
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Worksheet Voltage divider circuits
Textbook Rate-of-change indicator : Dc Circuits
Textbook Precision potentiometer : Dc Circuits
Textbook Potentiometer as a rheostat : Dc Circuits
Textbook Potentiometer as a voltage divider : Dc Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
need circuit for potentiometer for 12V backup alarm for RV dtsnyder The Projects Forum 1 10-08-2008 11:51 PM
Reduce sensitivity of potentiometer? diafygi The Projects Forum 5 10-08-2008 05:20 PM
what is the difference between a potentiometer and a variable resistor? mahela007 General Electronics Chat 5 09-14-2008 12:08 PM
Which potentiometer to use? dmc0162 The Projects Forum 3 12-19-2007 10:51 AM
Using small signals The Skeptic Homework Help 31 02-05-2006 11:38 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
