what is the difference between a potentiometer and a variable resistor?
Discussion in 'General Electronics Chat' started by mahela007, Sep 13, 2008.
  1. mahela007
    Thread Starter Active Member
    Jul 25, 2008
    45
    what the difference between a potentiometer and a variable resistor ?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    A variable resistor is made up of a potentiometer wired with the center leg tied to one or the other end of the pot. This permits it to act like a variable resistor.
    hgmjr
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here's a schematic to illustrate hgmjr's assertation.
    When wired as a potentiometer, the wiper (usually the middle connection) acts as a tap. In the circuit on the left, Vout could be a voltage anywhere between +V and -V, depending upon the setting of the pot.
    PackratKing likes this.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Another term used in place of variable-resistor is "rheostat" as mentioned by sgtwookie.
    hgmjr
  5. mik3
    Feb 4, 2008
    4,846
    63
    A variable resistor is a two terminal component which you can vary its resistance by rotating an axis or by sliding a conduct along its axis (big one, usually used in labs for experiments).
    A pot is a three terminal component which you can use as a variable resistor (as SgtWookie said) and to obtain a variable voltage on one of its pins by rotating its axis by your fingers (panel mounted pots, you can use them frequently) or by a screwdriver (trimmers, usually used on PCB's to adjust something for a few times because they fail if you use them frequently).
  6. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
