| Embedded Systems and Microcontrollers Discussion forum for projects and working with embedded systems and microcontrollers (FPGAs, PICs, AVRs). Get help with hardware issues and embedded programming. |
Thread Tools | Display Modes |
#1
I have to make a 8051 Project in which i have to display four digits one after the other with the delay of 30 seconds between each display. After the display of digits i have to display four alphabets with same delay between each display. Any suggestions ??
But the major issue here is that i also have to make the power supply circuit for the above project and have to give proper reasoning behind the usage of a particular device. Any help ?? I have some few ideas: For the Power Supply circuit i plan to use: One 9 V trannsformer One IC 7805 One IN 4007 One Ceramic Capacitor- .1 uF For the Microontroller Project: 8051 Microcontroller Four 7 segment common anode displays One crystal oscillator 11.0592 Mhz Two Capcitor 53 pF Two Capacitor 10uF One 2-4 Decoder 74LS139 Ten Resistors of 10 KΩ Any suggestion would be eagerly anticipated !!! |
#2
I suggest you to put a 470uF capacitor at the output of the voltage regulator. Also, you will need some current limiting resistors for the displays.
By transformer you mean an AC/DC adaptor or just a single transformer?
__________________
>> Troubleshooting is an art << http://www.youtube.com/watch?v=hC7KYbFBPHA http://www.youtube.com/watch?v=StNJlRTWs9k http://www.youtube.com/watch?v=j-4h3l9O4fc http://www.youtube.com/watch?v=E0jZJ...eature=related |
#3
I mean a single transformer but i would really be happy if yyou can guide me in right direction.
#4
You need to use a bridge rectifier to rectify the output of the transformer and an electrolytic capacitor of about 1000uF after the output of the rectifier. After the capacitor connect the voltage regulator.
__________________
#5
It would be better to buy a ready one AC/DC power supply to drive your circuit but take care of it to be regulated.
__________________
#6
YOu can try the Atmel AT89C5131 for your choice of 8051. Codes can be downloaded into this chip from your PC USB port by using the free FLIP software from Atmel. No programmer needed.
A simple ac/dc power adaptor plus the use of a 7805 should do fine for the power unit. |
#7
Thanks for all your help.
Project successfully implemented. |
| Bookmarks |
| Tags |
| 8051, microcontroller, power, project, supply |
| Thread Tools | |
| Display Modes | |
