Since there have been repeated claims that phasors are not vectors I decided to test this against the mathematical definition of a vector that has been in use for more than a century now.
According to my literature, this codification of vectors was first introduced by Peano in 1888 (Calcolo Geometrico) and strengthened by Weyl in 1918 (Space-Time-Matter).
This definition has been in use ever since.
A non-empty set of objects, T,
taken with a second non-empty set of objects F,
and two operations connecting these objects
is said to be a vector space and the objects of T are said to be vectors
if the following conditions (numbered 1 through 10) are satisfied by each and every object in T and F.
The objects of F are called scalars and are often (but not always) real or complex numbers.
One of the two operations is a rule which takes any two vectors u and v from set T and connects them to a third vector w, also from T.
We call this addition and use the + sign to denote it.
Thus w = u + v
The second operation connects vectors in the first set with scalars from the second and is called multiplication by a scalar. It takes any vector v from T and any scalar a from F and outputs the vector av, also in T.
I have used bold capitals for objects of V . the vectors
and normal, lower case for the objects of F .the scalars
The 10 axioms to be satisfied are
(1) if u and v are in T then w = (u+v) is in T
(2) u +v = v + u
(3) u + (v+w) = (u + v) + w
(4) There is an vector in T called the zero vector such that for all v in T
0 + v = v + 0 = 0
(5) For each and every vector, v in T there is a vector v such that
v + (-v) = 0
(6) If k is any scalar in F and v is any vector in T then there is a vector kv in T
(7) K(u + v) = ku = kv
(8) (k+l)v = kv + lv
(9) k(lv) = (kl)v
(10) There exists a scalar 1, in F, such that 1v = v
If I can find (define) a set of object obeying these rules I can call the object vectors.
Of course the rules are framed to include all the normal geometric and other sorts of vectors as subsets.
Thus w = u + v
(2) u +v = v + u
0 + v = v + 0 = 0
v + (-v) = 0
(9) k(lv) = (kl)v
