| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#1
can we apply single phase 230v,50 hz, ac supply directly to the igbt?
should be the rectifier included?if not what will be the sequence? awaiting for your valuable replies and suggestions.... |
#2
No you cant. If you want to control AC loads use TRIACS or solid state relays designed for AC operation.
__________________
>> Troubleshooting is an art << http://www.youtube.com/watch?v=hC7KYbFBPHA http://www.youtube.com/watch?v=StNJlRTWs9k http://www.youtube.com/watch?v=j-4h3l9O4fc http://www.youtube.com/watch?v=E0jZJ...eature=related |
#3
if we apply ac supply to the igbt ,what will happen?
will it damage igbt? my silly doubt is if we can apply swithced dc(similar to ac),cant we apply pure ac? awaiting for your patience reply.thank you. |
#4
The IGBT will be destroyed. They are DC devices. The drain voltage must never go negative relative to the source. Get the data sheet and read that if you still have doubts.
__________________
First comes the hardware, then the software. |
#5
thank you very much for your valuable replies and guidance.
| Tags |
| function, igbt |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| IGBT circuit design | hensem | The Projects Forum | 8 | 01-24-2012 09:28 AM |
| transfer function | jenks | Homework Help | 1 | 04-24-2008 12:44 PM |
| Dirichlet conditions for the Fourier series | jagjit Sehra | Math | 7 | 03-23-2008 10:20 AM |
| Finding the transfer function... | snowfox | Homework Help | 14 | 11-15-2007 07:21 PM |
| GUI project in mat lab | m75allen | Programmer's Corner | 6 | 05-30-2007 11:51 AM |
| Thread Tools | |
| Display Modes | |
