All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-04-2008, 10:35 PM
guitarguy12387 guitarguy12387 is offline
Default Complex Fourier series of full wave rectifier
I have a full wave rectified sine wave. Basically, the graph looks like abs(sinx).
When calculating the coefficients, i have tried evaluating:
∫[sin(t)exp(-jnt)]dt from 0 to pi.
and am not getting the correct answer.
I'm wondering if i need to just look for a computation error... or if I am setting the problem up wrong.
I'm having doubts about if i'm allowed to setup the integral as such.
Thanks.
  #2
Old 10-06-2008, 02:29 PM
Mark44 Mark44 is offline
Default
Thanks.
The function you give, f(x) = |sin x|, is an even function, so its Fourier series consists only of cosine terms. An even function is one for which f(-x) = f(x), for all x in the domain of f.
You can also find the Fourier coefficients using the approach you showed, and the integral is c_n = 1/(2pi)∫f(t) exp(-jnt) dt, integrated from -pi to pi.
You need to take into account the fact that your function is equal to -sin(t) on the interval -pi to 0, so the integral above can be rewritten as
c_n = 1/(2pi) ∫ -sin(t) exp(-jnt) dt + 1/(2pi) ∫ -sin(t) exp(-jnt) dt,
with the limits of integration for first integral are -pi to 0, and for the second, 0 to pi.
Mark
__________________
"The floggings will continue until morale improves!"
  #3
Old 10-06-2008, 03:00 PM
Default
ahhh ok. Thanks Mark.
Won't that result in integrating over TWO periods of the function though? Is that allowed?
  #4
Old 10-06-2008, 07:12 PM
Default
Figured it out...
Apparently i had the right approach, but i had the wrong argument in the exponential. Oops heh. Thanks again, Mark.
  #5
Old 10-06-2008, 08:25 PM
Default
Good point.
__________________
  #6
Old 10-06-2008, 08:27 PM
Default
Figured it out...
Was the work that you actually did different from what you posted? I didn't notice anything obviously wrong in what you posted.
__________________
  #7
Old 10-06-2008, 09:29 PM
Default
Just the exponential... since ω = 2pi/T = 2, it should have been:
∫[sin(t)exp(-j2nt)]dt from 0 to pi
Tags
Related Site Pages
Section Title
Worksheet Mixed-frequency signals
Worksheet Phasor mathematics
Similar Threads
Thread Thread Starter Forum Replies Last Post
A Full wave precision rectifier query trytolearn General Electronics Chat 14 02-12-2009 04:51 PM
smooth DC output from full wave rectifier davidhills General Electronics Chat 11 09-21-2008 04:51 PM
Complex Fourier Series Coefficients ohwcomp Homework Help 4 09-18-2008 01:12 PM
i need a simple full wave rectifier application with circuits raghavan General Electronics Chat 1 07-11-2008 04:17 AM
How to make Hi Speed Full wave rectifier PSIR General Electronics Chat 11 04-25-2008 06:24 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
