All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
View Poll Results: To improve..
Thread Starter needs to read more. 1 50.00%
Thread Starter needs to experiment more. 1 50.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-23-2008, 04:34 PM
Slasherbaven Slasherbaven is offline
Junior Member
Default [Help] Battery Monitor Circuit
I've created a schematic of a Battery Monitor, where it monitors three voltage ranges:
0~5V
5V~9V
9V~12V
However.. I am unsure of my circuit.
So yeah, well before I build the circuit, can any of you guys double check this for me?
Really sorry for the bother
Thanks in advance. =]
(Attached to this post is the Battery Monitor schematic)
  #2
Old 07-23-2008, 05:33 PM
blocco a spirale blocco a spirale is offline
Default
This won't work. I think it would be best to start again rather than try and fix it.
  #3
Old 07-23-2008, 05:37 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Default
Yes, it needs work.
1) Use comparators instead of operational amplifiers. Op amps should not be used as comparators; they weren't really designed to be run in open-loop mode indefinitely. Power consumption will be far higher than comparators, as the outputs of the opamp will be in constant saturation. Consider using an LM339 quad comparator, or better yet use an IC that's really designed for this type of thing, an LM3914N. Comparators and 10 LED drivers are built right into this IC.
2) Your LEDs do not have current limiting resistors.
3) The op amps have only negative supply and ground; no positive supply.
4) Although you've provided a 2.5v reference to the resistor ladder for the inverting inputs, the noninverting inputs see full battery voltage. As a result, the outputs will not change states until the battery voltage falls below the minimum input voltage of the TLE2425, at which point the outputs will be unpredictable.
5) Battery voltage remains remarkably constant from when they are fully charged until when they are nearly discharged. An automotive 12.6v battery is considered fully discharged at 11.4v. Dry cells have somewhat different levels, but it's a similar concept.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #4
Old 07-31-2008, 06:30 AM
Junior Member
Default
I'm a bit confused...
Sergant Wookie, I am required to use an LM324 quad (a low-power quad Op-Amp) for the circuit.
And here, I re-did the whole thing.
Hopefully it's better than the one before.
The Vcc's purpose is to power up the op-amps.
  #5
Old 07-31-2008, 01:06 PM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
There is an open circuit. There is no current path through the resistors. There will be no voltage across them.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #6
Old 07-31-2008, 01:53 PM
Junior Member
Default
>_< Alright, here's another one.
It seems quite right.
I'll start fixing things from here.
=EDIT=
The earlier post was deleted by accident.
Sorry about that.
  #7
Old 07-31-2008, 03:28 PM
KMoffett KMoffett is offline
Default
U1 (78L12) will not work for this because the battery on the input is only 10V. You were thinking of a 78L05 maybe? And the + terminals on the op amps are hooked to the (-) end of the 10V battery.
Ken
  #8
Old 07-31-2008, 03:53 PM
Junior Member
Default
Ah, my bad on the 10v battery and it's connection.
Here, I made the minor adjustment:
And as for the 78L12, why would using a 78L05 be better?
  #9
Old 07-31-2008, 04:12 PM
Default
1. For the 78L12 to regulate it needs an input of +14V or more. If your battery is 12v then the regulator has have an output of 10v or less to work. 78L05 is a common IC, but could be a 78L09 or 78L06.
2. The negative end of your battery should be hooked to ground, not the regulator's input. The regulators input should be tied to the battery's (+) terminal.
For the reference voltage, you need to research: three-terminal voltage regulators...how they work.
For level sensing you need to research: voltage dividers...for both of the comparator's inputs.
Ken
  #10
Old 07-31-2008, 04:33 PM
Junior Member
Default
Thank you for being patient, Ken.
I just read up on it, and it's pretty interesting.
Seems that the excess voltage dissipates as heat, and the hole on a regulator has to be attached to a heat sink.
Since I'm putting in a 12V, there'll be an excess of up to 5V, so I shall put a heat sink to be safe.
Thank you.
I'm sorry, but level sensing is..?
There we go:
I'm still a bit confused as to why, but will reading up more details on regulators help?
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
battery charging circuit kppp General Electronics Chat 1 03-08-2009 03:45 AM
power circuit with battery needed router_help The Projects Forum 3 01-04-2009 07:30 AM
ALKALINE BATTERY CHARGER lildiesel6075 The Projects Forum 32 06-22-2007 12:51 AM
Hooking up 2 car battery chargers to 1 battery, in parallel gazzonyx The Projects Forum 7 03-10-2007 05:09 AM
Doubts about Battery sanketbarot The Projects Forum 2 03-05-2007 08:24 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
