Battery Powered Monitor Help
Flajubam
Joined Jun 1, 2016
Hi guys,
Bit of a silly one. Basically I want to make a life size gameboy costume which actually works. From what I've looked up so far the best way to do it would be to use a Rasberry Pi as the emulator which should be fine running off of a fairly big USB power bank.
My problem is when it comes to the screen. I am not sure how to get a decently sized one, say 15" to be run off of a battery and for said to battery to give me at least a few hours, preferably more,of play time. I am looking at possibly getting a laptop lcd screen and controller board to do it but am not confident on how to get it powered as the boards seems to take 12v and about 3-4A depending on the one you need.
So from what I know my options would be like a Lead Acid Battery, but really that would be too heavy for my liking.
Or to use a very big power bank, then use a step up transformer to 12v with a transistor to get the right amps. I don't know if this would work however or how safe it would be.
Or if any of you have any suggestions on other ways I could do this please let me know. Thank you in advance for your help!
wayneh
Joined Sep 9, 2010
17,498
Do you mean a backlit GameBoy? Backlighting will consume quite a bit of juice. My kids' GameBoys were never backlit, if I recall correctly.
not silly at all! having the ome. help us please! :)
Hi guys,
Flajubam
Joined Jun 1, 2016
I would need it back lit ideally. But yeah as you said I'd imagine that a screen of that size would take a fair bit of power so not quite sure how to do it without it dying constantly.
wayneh
Joined Sep 9, 2010
17,498
You're going to need lithium ion batteries, just like a laptop. They cost more than lead acid but have more power per weight and per volume. That's why they're ubiquitous in mobile devices these days. I think you might find a laptop replacement battery pack with enough juice. If you need to go cheap, I'd pick an old 17" laptop model that you can use as a fancy charger, and a fresh replacement battery pack for it. The computer should be nearly free if it has other problems, and will work for you as long as it can charge a battery.
Maybe there are other options, like an e-bike battery? Skateboard battery? RC plane? Not sure.
