All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-11-2008, 06:03 AM
fancy102 fancy102 is offline
Junior Member
Default leading or lagging power factor
hi..i am carrying out power factor measurement system and i need to know the power quality.
my problem is how can i know the current is leading the voltage or lagging the voltage?i can know it through ossiloscope only?still got any other way to know current leading or lagging voltage?thanks
  #2
Old 03-11-2008, 02:06 PM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
"ELI the ICE man." Current lags voltage in an inductive circuit. Current leads voltage in a capacitive circuit.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #3
Old 03-11-2008, 04:32 PM
mrmount mrmount is offline
Member
Default
You can use power factor meter if you want!
  #4
Old 03-12-2008, 12:19 AM
Junior Member
Default
I am doing the power factor metre...so i would like to show the lagging or leading to the user...so except ossilocope i cant know leading or lagging through calculation?
  #5
Old 03-12-2008, 01:47 AM
mik3's Avatar
mik3 mik3 is offline
Default
You can connect a very low resistor (lets say 1 ohm or less, take care it can handle the power dissipation ) in series with the load. Then monitor the voltage across the resistor with an amplifier which drives a led. Also monitor the voltage across your load with an amplifier too or if it does not need amplification use a buffer which again will drive a led. Note that both the amplifier and buffer must have high input impedance.
Then with this method you will see which led goes to full illumination first.
If the led from the resistor goes bright first it means that you have a capacitive load and the power factor is leading
if the led from the load goes on first it means you have an inductive load and the power factor is lagging.
Note: make the appropriate connections to the buffer and dont connect it directly to the load if it high voltage.
  #6
Old 03-13-2008, 11:51 PM
Junior Member
Default
u mean connect a LED series to the load? then the other one connect to the ouput of the comparator(current)?
why do i need buffer??sorry for the poor knowledge...thanks
  #7
Old 03-14-2008, 12:09 AM
mik3's Avatar
Default
why do you need to know this about the power factor?
  #8
Old 03-14-2008, 02:12 AM
Junior Member
Default
because i am carrying out power factor measurement system. i need to know the power factor of the system and current is leading or lagging...
  #9
Old 03-15-2008, 11:46 PM
Junior Member
Default
sorry to ask again...the phase angle of the power factor should not more than 90 degrees no matter what is the load?is this correct?
if it is capacitive than should negative phase angle and if inductive than should be positive phase angle?is the concept correct??
thanks a lot!!
  #10
Old 01-07-2010, 08:56 AM
hitmen hitmen is offline
Default
sorry to ask again...the phase angle of the power factor should not more than 90 degrees no matter what is the load?is this correct? (Not sure never encountered before)
if it is capacitive than should negative phase angle and if inductive than should be positive phase angle?is the concept correct?? (yes)
Tags
Related Site Pages
Section Title
Worksheet AC power
Worksheet Inductive reactance
Textbook Synchronous condenser : Ac Motors
Textbook Practical power factor correction : Power Factor
Textbook Calculating power factor : Power Factor
Textbook Mutual inductance and basic operation : Transformers
Worksheet Kirchhoff's Laws
Textbook AC capacitor circuits : Reactance And Impedance -- Capacitive
Video Lecture Sine Wave Characteristics (cont) - Alternating Current
Textbook AC inductor circuits : Reactance And Impedance -- Inductive
Similar Threads
Thread Thread Starter Forum Replies Last Post
Power Factor Correction 2rlp General Electronics Chat 13 07-19-2008 07:02 PM
Lagging or Leading Power Factor ha4nguyen Homework Help 4 03-06-2008 05:49 PM
about power factor papa Homework Help 4 11-29-2007 03:26 PM
why do industries want to keep their power factor nearest to one? Faheem Khan General Electronics Chat 3 06-07-2007 06:57 PM
Power factor correction eaj0010 Homework Help 2 09-11-2005 08:41 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
