All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Electronics Resources
Notices
Electronics Resources Get help with all types of electronics resources, including books, websites, datasheets, technical literature, and software.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-26-2012, 03:12 PM
BobW55 BobW55 is offline
Junior Member
Default low profile quadrature encoder
I am looking for a very low profile encoder to go on the end of a motor shaft. I only have about 1/4" of end shaft to hook on to. I can mount a pulse wheel no problem but only have limited space between the motor housing and the wheel. Any ideas?
I am also looking at the possibility of using a shaft mounted encoder with a gear drive.
Bob
  #2
Old 03-26-2012, 03:57 PM
crutschow's Avatar
crutschow crutschow is offline
Senior Member
Default
As always, the devil is in the requirement details. What type of encoder resolution and output do you need?
__________________
Zapper
Curmudgeon Elektroniker
  #3
Old 03-26-2012, 05:44 PM
Junior Member
Default
20 pulses per rev would be more than enough, no matter if I use the motor end or a shaft/gear drive.
Will have to post a picture of the motor end, would explain better then words.
  #4
Old 03-27-2012, 04:11 PM
crutschow's Avatar
Senior Member
Default
Perhaps an opto interrupter would work.
__________________
Zapper
  #5
Old 03-28-2012, 09:28 AM
advtakpcb advtakpcb is offline
New Member
Send a message via MSN to advtakpcb Send a message via Skype™ to advtakpcb
Default
Low profile.
  #6
Old 03-28-2012, 12:40 PM
MrChips's Avatar
MrChips MrChips is online now
Senior Member
Default
Salvage parts from a ball mouse.
__________________
Most computer problems can be attributed to a simple problem - a loosewire behind the keyboard.
  #7
Old 04-05-2012, 09:43 AM
chrisw1990 chrisw1990 is offline
Senior Member
Default
Quote:
Originally Posted by advtakpcb View Post
Low profile.
opto interupter is low profile....
__________________
if in doubt.. use a hammer.
  #8
Old 04-05-2012, 10:13 AM
strantor's Avatar
strantor strantor is offline
Senior Member
Default
http://www.dynapar.com/uploadedFiles...Rotopulser.pdf
Tags
Related Site Pages
Section Title
Worksheet Servo motor systems
Textbook Selsyn (synchro) motors : Ac Motors
Textbook Synchronous Motors : Ac Motors
Textbook Synchronous counters : Sequential Circuits Counters
Similar Threads
Thread Thread Starter Forum Replies Last Post
Low distortion low power amplifier DarkAvenger The Projects Forum 7 01-13-2012 04:13 AM
Stepper motor help (very hot!) jmbillings The Projects Forum 6 01-01-2012 05:33 PM
High AC & LOW AC tripping not working asimraufawan The Projects Forum 6 12-31-2009 02:56 PM
High voltage extremely low currents Ynot1980 Off-Topic 1 12-16-2009 11:32 PM
Quadrature on PIC16f684 Dalaran Embedded Systems and Microcontrollers 11 12-08-2009 01:06 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
