low profile quadrature encoder
Discussion in 'Electronics Resources' started by BobW55, Mar 26, 2012.
  1. BobW55
    Thread Starter Active Member
    Jul 22, 2008
    43
    I am looking for a very low profile encoder to go on the end of a motor shaft. I only have about 1/4" of end shaft to hook on to. I can mount a pulse wheel no problem but only have limited space between the motor housing and the wheel. Any ideas?
    I am also looking at the possibility of using a shaft mounted encoder with a gear drive.
    Bob
  2. crutschow
    Mar 14, 2008
    13,475
    3,362
    As always, the devil is in the requirement details. What type of encoder resolution and output do you need?
  3. BobW55
    Jul 22, 2008
    43
    20 pulses per rev would be more than enough, no matter if I use the motor end or a shaft/gear drive.
    Will have to post a picture of the motor end, would explain better then words.
      File size:
      284.8 KB
      21
  4. crutschow
    Mar 14, 2008
    13,475
    3,362
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    Salvage parts from a ball mouse.
  6. chrisw1990
    Oct 22, 2011
    543
    41
    opto interupter is low profile....
  7. strantor
    Oct 3, 2010
    4,302
    1,989
