very strong magnet ?
R!f@@
Joined Apr 2, 2009
10,004
size matters when it comes to electro magnets buddy....the bigger, more power required, more powerful magnet
rjenkins
Joined Nov 6, 2005
1,013
The relative strength of an electromagnet is measured by it's Ampere-Turns rating.
More turns and/or more current increase the strength.
You are limited on current by how much the wire is rated for (and heat build-up within the coil), turns are only limited by size.
The absolute strength also depends on the magnetic core and physical layout.
Depending what you mean by 'small', you probably cannot match the strength of a small neodymium permanent magnet.
Even for small industrial lifting on cranes, permanent magnets are used in preference to electromagnets.
hgmjr
Joined Jan 28, 2005
9,027
hi , and how can someone make a very powerful electric magnet , and also with small size ?
As I understand it, the amount of power in a magnet is only a small fraction of the power it took to manufacture the magnet in the first instance.
hgmjr
A very strong DC electromagnet can be made by machining a cup out of a steel billet, leaving a center pole that will accept a wire-wound bobbin.
You can experiment with various numbers of magnet-wire turns to get an idea of the strength factor, (amperes x turns).
Cheers, DPW [ Everything has limitations...and I hate limitations.]
KL7AJ
Joined Nov 4, 2008
2,229
You can get rare earth magnets from Radio Shack or Edmund Scientific, and a lot of other science supply houses.
Also, you can disassemble an old hard drive and get some mighty powerful magnets.
Eric
bhvm
Joined Jul 16, 2009
53
Ask Politely to any PC shop and get an Old, damaged Desktop HDD.
HDDs have one of the BEST EVER Rare earth magnets!
These are permanent magnets, not electros.
I ripped apart one and It was so hard even to get out!
Actually, i thought it was glued, but! Actually the magnet itself was so strongly attached to the casing.
