Very strong and very small electric motor
Discussion in 'General Electronics Chat' started by peranders, Nov 26, 2009.
  1. peranders
    May 21, 2007
    87
    I'm searching for this:
    230 VAC and 3 x 400 VAC (maybe more), 50-60 Hz
    Up to 4 kW but less for the single phase version
    I need 1.7-1.8 kW to the load
    Good efficiency
    Small, cola can size or in that region.
    IP67 water proof
    Ex environment (really harsh environment)
    Can be water cooled since I have running water
    Rotation speed 3000-6000 rpm not a problem but the end speed is 6-10 rpm via a gear box
    Speed control of the motor but only a soft start than max speed for 5-10 minutes.
    I haven't got a clue which type of motor I should look for but I'll guess something for 300-500 V internally and no brushes since the service interval should be long.
    Ping motor experts!
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    You need to put this in the electronics area, this is for off topics.
  3. peranders
    May 21, 2007
    87
    I thought this was not particular electronical so could some nice moderator move this thread please?
