Thin lens
boks
Joined Oct 10, 2008
218
What happens to the projection if the object is put right at the focal
point of the lens? The image will be projected at infinity, right? How about if you place the object even closer to the lens, i.e. between the lens and the focal point?
Wendy
Joined Mar 24, 2008
23,797
Think in terms of collimation. This is basic optics physics, I think. On either side of the focal point the image will either be inverted (and spread) or just spread out.
From the title of your post, I thought you were talking about a Frensel Lense.
Tesla23
Joined May 10, 2009
560
If the object is between the focal point and the lens then the image is virtual and magnified. This is how a magnifying glass works. You can't project a virtual image on a screen. Google should find you more details.
Skeebopstop
Joined Jan 9, 2009
358
Mind you no lens in perfect so no focal point a singularity and that objects are 3D so infinitely projected without dispersion impossible.
