If the object is between the focal point and the lens then the image is virtual and magnified. This is how a magnifying glass works. You can't project a virtual image on a screen. Google should find you more details.What happens to the projection if the object is put right at the focal
point of the lens? The image will be projected at infinity, right? How about if you place the object even closer to the lens, i.e. between the lens and the focal point?
by Duane Benson
by Aaron Carman
by Jake Hertz
by Jake Hertz
