Vapor Smoothing Chamber
Introduction
I am building a heated smoothing chamber for 3d prints. I’ve been using a ‘cold vapor’ method quite successfully but the process typically takes hours. Heating the solvent should reduce the time required to just a few minutes. I will be testing with ABS filament and acetone solvent however it should be able to accommodate other solvents. I have been provided a MAX31856 board and thermocouple which will be used for solvent temperature measurement. For temperature regulation and general device control, I chose an 8-bit 28 pin Microchip PIC18F26K42. To be continued...
BOM
List all the parts required for your project.
Schematics
Upload your schematic files or images
Instructions
Explain how you built your project! Please be sure to include rich technical information and images. You can drag and drop images from your desktop directly into this editor.
Video
Let's see your project in action! Paste the YouTube link here and it will automatically be embedded.
Source Code
Code:
Paste your project source code here, or upload an attachment.
CAD Files
Attach or link to any CAD files if relevant to your project.
Blog entry information
Author
Greg Lemons
Views
314
Last update
More entries in General
Share this entry
