An interesting circuit once appeared under this thread:
http://forum.allaboutcircuits.com/showthread.php?t=43005
and I thought I would show how I solved it.
Using just 3 node voltage method equations.
The original problem said: "Find the resistance between points A and B if R=81 Ω.
This is the original circuit, posted by the OP:
All resistors are 81 Ω
Now this is what I did:
1. I re-drew the circuit to make it look neater.
2. I converted the three last resistors into 1.
3. I labeled E1,E2,E3 nodes.
4. I applied Node Voltage method.
And since the voltages E1, E3, are 3.5V, 2.8V, respectively, it follows that:
(3.5V/81) + (2.8V/81) = 77.77mA
Which means that the total circuit resistance is: 90 Ω
Thanks to Tony Kuphaltd for his great book.
Thanks to Qucs software for Linux to draw the schematics.
And thank you guys for letting me post this on the forum!
