This is one simple mini-project that based on the principle of Motor effect.we can clearly visualized the rotating effect when the magnetic flux of magnet is intersect with magnetic flux due to the supply current.
Apparatus required:
1) magnet
2) insulated wire
3) one box
4) power supply
Construction Detail:
View attachment 256 View attachment 253
- Take insulated wire and make a coil of about 12 to15 turn and keep two end out in such a way that is properly balance.
- make two stand by some hard wire that support coil.
- connect this stand with power supply.
- remove insulation of the half part outward projected insulated wire coil (that is connected with stand only in half rotation and half rotation is completed by mean of inertia. )
- switch on the power supply and your project.
