Regulated breadboard powersupply
I got inspired by one of the threads on the forum, and that ended up with this. My way of making a workbench/bread board powersupply.
The input source is a wall wart 30v 1.5A.
It's limited to regulate down to 12vdc and 5vdc. Nothing more and nothing less.
I design my schematics in Eagle, here is the schematic:
Click on image for bigger view.
... and a panelized version of the board layout:
The process:
After the design is finished, and I'm satisfied with the board layout, I print it on transparent sheet. Twice. This way, when I put them on top of each other, the UV-light is completely blocked. After development, it leaves a nearly perfect result. Next is the etching. That's done in Ferric Chloride. I've made my own agitator, to speed up the process. I could also heat the etchant a bit, but I don't do that. It's around room temperature.
When etching was done, I sanded the board with super fine sand paper, and cleaned it with Acetone. Both sides. That also removed the rest of the photoresist that was left. Next I drilled a hole to hang the board up while painting. I've bought some paint. This type from Bungard I painted both sides, and was a bit excited about the solder side. Would the paint do it impossible to solder? Well, it didn't. I was easy to solder this.
The finished pcb and solder product.
I think it looks really nice.
Here's some better pictures.
Disclaimer:
I take no responsibility for what others might do with the schematic, circuit or paintjobs. This work for me, though the schema and circuit might not be 100% efficient or optimized.
Blog entry information
Author
nerdegutta
Views
1,415
2
Last update
Downloads
More entries in General
More entries from nerdegutta
Share this entry
