I decided to make luxmeter, which has basic functions:
1. measure lux from 0 to 188000 lux
2. calculate watts/m2
3. charging using USB cabel via TP4056 board
Basic sensor is MAX44009, which measure lux. I use Arduino Pro Mini as microcontroller.
Totally it cost cca 13 $. Case is homemade.
Power consumption - 15 mA.
for more info: https://www.instructables.com/id/Portable-Luxmeter/
BOM:
BOM:
Arduino Pro Mini 5V
Link: https://www.aliexpress.com/item/329...&terminal_id=6f16b2047f114c94a07652c7f0a9951a
MAX44009
0.045 Lux to 188,000 Lux Range
VCC = 1.7V to 3.6V
ICC = 0.65µA Operating Current
-40°C to +85°C Temperature Range
Link
https://www.aliexpress.com/item/328...&terminal_id=6f16b2047f114c94a07652c7f0a9951a
OLED display
Link: https://www.aliexpress.com/item/328...&terminal_id=6f16b2047f114c94a07652c7f0a9951a
Diagonal Screen Size:0.96"
Number of Pixels:128 x 64
Color Depth:Monochrome (Yellow&Blue)
Dimension:27.8 x27.3x 4.3 mm
Working Voltage: 3.3~ 5V DC
Power: 0.06W
MaxViewing Angle: >160 Degree
Duty:1/32Brightness ( cd/m2):150 (Typ) @ 5V
Interface: I2C
TP4056
input 5V
Link: https://www.aliexpress.com/item/324...&terminal_id=6f16b2047f114c94a07652c7f0a9951a
Li-Ion battery
3 - 4.2 V
18650 holder
Link: https://www.aliexpress.com/item/326...&terminal_id=6f16b2047f114c94a07652c7f0a9951a
Switch jumper
Dupont cable a pin headers
pin headers
Circuit:
You need of course 5V Arduino to power it with Li-Ion battery (4,2 V!)
Code:
// OLED display TWI address
#define OLED_ADDR 0x3C
Adafruit_SSD1306 display(-1); // restart display with reset button on arduino
void setup()
Lux.Begin(0, 188000);
display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDR);
display.clearDisplay();
display.display();
// display a line of text
display.setTextSize(1);
display.setTextColor(WHITE);
display.setFont(&FreeSerif9pt7b);
display.setCursor(1,15);
display.print("MAX44009");
display.display();
void loop()
lux=Lux.GetLux(); // get luxs
watts =Lux.GetWpm(); // get watts/m2, only for SUN source
display.fillRect(1, 20, 100, 100, BLACK); // create black rectangle on values position
display.setCursor(1,40);
display.print(lux);
display.setCursor(80,40);
display.print("lux");
display.setCursor(1,60);
display.print(watts);
display.setCursor(80,60);
display.print("W/m");
display.setCursor(115,55);
display.print("2");
display.display();
delay(1000);
Photos:
Charging
Night pollution?
