PIC10F202 charliplexing "knight rider" display
6 LED display with 3 output pins. ASM code and video link attached. The video should play with realplayer. It should also fit on a 10F200 with minor modification.
I'm going to make a tiny PCB and use 0402 surface mount LEDs (0.5mm X 1mm).
The display part will probably be 5mm X 1mm.
http://www.marksphotos.info/knight/MOV00278.3GP
I've made the small version. I've also changed the code because I swapped GP1 and GP2 and the LEDs were originally always slightly lit, which looked OK with 5mm LEDS, but not with the 0402s.
charlie2.txt is the new code.
As usual my soldering is a bit wonky, but I'm getting better.
http://www.marksphotos.info/knight/MOV00284.3GP
Blog entry information
Author
Markd77
Views
1,470
2
Last update
More entries in General
Share this entry
