Hi ALL!
About the OWON SDS7102V encoders Fail, brand Everbest.
I changed the encoders but the new one drive inverse.
You need to make a jump to connect right side to left PCB pad and left side to right PCB pad.
Only cut left and right encoder legs but left a short terminal to you can solder a wire and solder the another wire point to the other side pad in the PCB and do the same to the another leg.
The problem about the encoders get fail is because they have grease inside to make they heavy to turn to do not turn easy. The grease is made of something meltable. It melt and flow to the encoder contacts and there do a film of insulation. If you can open the encoder and clean it with solvent, you will have it back in order to work for some time but you can apply some soft grease to give long life to the contacts.
Thank you
Thank you
