Interfacing AD698 with Half Bridge LVDT
Hi,
I'm armature to electronics (Computer Engineer by profession) . And, i'm doing some automation project. In that i have to read a Half bridge LVDT transducer, particularly solartron AX/1/SH. I got its test condition document, attached as image here.
i am working on it using AD698AP. and i'm finding it difficult for designing a circuit to get the experiment carried out. Will some one please suggest the circuit and value. Also, what type of capacitor should i use as i want to design a thru hole component PCB for ease of use. I'm referring fig.7 from the datasheet and trying to have experiment. (in which eventually i damaged 2 IC's). C1=7nf, C2=C3=C4=1uF. But what should i use for rest of values and based on form here, which changes should i make in the circuit?
I want the circuit to have single power supply (Boost converter module XL6009), and output as mentioned in design reference shown below, so i can carry my rest of the project by implementing I2C on ADC. Need help please..
Blog entry information
Author
Pritesh Shirsath (Ren)
Views
914
Last update
More entries in General
Share this entry
