How to solve Microwave Engineering Pozar chapter 05 example 01 with MATLAB
Question:
Literature source [POZAR] available here:
https://www.amazon.co.uk/Microwave-Engineering-David-M-Pozar/dp/0470631554
There's also a solutions manual available here:
https://www.scribd.com/doc/176505749/Microwave-engineering-pozar-4th-Ed-solutions-manual
Answer:
MATLAB script source pozar_05_example_01.m and all necessary support functions included in .zip here attached file pozar_05_example_01.zip
including detailed explanation. Following, the key points:
For the given load, the component values are
C1 = 9.227738300997709e-13
ctype =C [Farad]
L1 = 3.898484006168380e-08
ltype =L [Henry]
L2 = 2.167378326912196e+07
ctype =L [Henry]
C2 = 3.847649490485592e+11
ltype =C [Farad]
with frequency response
With ADS, using the component DA_SmithCharftMatch that opens the Smith Chart Utility
that readily obtains the component values
the term 'series' is here used as the jX component connected in both circuits as above.
But in some literature sources like [MEDLY] a distinction is made between 'cascade' that would the jX component connection above, and 'series' would be this:
[MEDLY] Microwave and RF Circuits: Analysis, Synthesis and Design. Author Max W Medley Jr.
John BG
Blog entry information
Author
John_2016
Views
452
Last update
Downloads
More entries in General
More entries from John_2016
Share this entry
