Fed connector presentation
Firstly, a visual comparison ('Real Fed' vs. 'Mini-Fed'):
And now a minute 'exploration' of bona fide Federal Standard Connectors...
Beginning with 3 external views of an 'unadorned' well:
And an interior view -- Note the keyway (annotated):
Well-flange hardware:
Hardware fully installed on (upright) well:
Now for a look at an uninstalled Federal Standard PLUG: Note 'key' (lower facing)
Juxtaposition of plug (foreground) and well (background) --
Again note 'key' near top (to wit: left end as pictured) of plug:
Plug partially inserted into well:
Plug fully inserted into well:
Plug installed on cable:
Cable-lock cap detail
-- Note threaded 'inner-ring' (annotated):
View of Well (lower left), Plug (lower center), Near-end of cable & lock cap (lower right). --- Note 'counterparts' at 'opposite' end of cable...
Plug assembly partially inserted into well.
Plug assembly fully inserted into well.
Note location of the retainer/lock-cap threads (annotated)
Lock-cap fully tightened -- plug/cable locked to well:
Note that although the cable shown in these images is partially armored -- Cu braid (immediately beneath the polymer jacket) covers the entire cable! -- The armor is merely by way of 'mechanical' damage preclusion with negligible electrical function...
Blog entry information
Author
Hypatia's Protege
Views
276
Last update
More entries in General
More entries from Hypatia's Protege
Share this entry
