When shopping for a new scope a lot of things need to be considered: what bandwidth do I need? what sample rate and sample memory is required? Do I need additional functionality like serial decoding, or an MSO? Do I need active probing? And so on.
However, there is one recommendation that...
Quite often the question arises what oscilloscope bandwidth is required to probe a certain bus or serial interface, so in a moment of boredom I assembled the following table from various sources.
Serial Standard|Bit Rate|Minimum Bandwidth req'd (Decode)|Minimum Bandwidth req'd (Signal...
The following is Part 3 of a review and quick teardown of a LeCroy WaveRunner LT224 digital oscilloscope I wrote in another forum in March 21, 2013. Part 1 can be found here, Part 2 is here. I now longer own that scope.
The Teardown:
Here are a few images from the inside of a Waverunner LT...
The following is Part 2 of a review of a LeCroy WaveRunner LT224 digital oscilloscope I wrote in another forum in March 21, 2013. Part 1 can be found here. I now longer own that scope.
My Waverunner LT 224:
The scope I got is a Waverunner LT 224. It's a 4-channel 200MHz scope with 200MSa/s...
The following is a review of a LeCroy WaveRunner LT224 digital oscilloscope I wrote in another forum in March 21, 2013, and which I reproduce here for availability reasons (I no longer own that scope!):
Recently I acquired what is my first own LeCroy oscilloscope. I have used other LeCroys on...
So that's it, my new home. A modern backend for the forum and the other sections, moderators seem relaxed, and people are friendly. I like that place :)
For those that don't know me from my old place: I wont go into much detail as I value my privacy and always maintain a strict separation...
