6 LED display with 3 output pins. ASM code and video link attached. The video should play with realplayer. It should also fit on a 10F200 with minor modification.
I'm going to make a tiny PCB and use 0402 surface mount LEDs (0.5mm X 1mm).
The display part will probably be 5mm X 1mm...
