- Joined Jan 23, 2018
- 18,519
It certainly looks like Q202 and @201 are muting transistors, intended to hold the inputs bypassed until everything is ready.
Next, for all of the reported voltages, I am GUESSING that the readings are relative to the supply common level, (ground), which I guess is an OK measurement. But when reporting only a single connection voltage it makes us look up what the readings were on the other connections. Base voltage 6 volts, emitter 1.5 volts, so the transistor is hard into saturation. Or it should be, but not seeing collector volts we have no clue. To know what a transistor is doing we need to know all three voltages. And it is still not clear if the right channel +20 volts is due to a loss of "pull down" or an excess of "pull up".
