I have been browsing through the forums trying to find an answer to my question but haven't had much luck. Here's my dilemma:
I have an old conveyor system that I'm trying to get operational again (more as a gadget... not industrial use, etc. Eventually want to use it as an off-feed table for my table saw). No motor or wiring came with the conveyor, but I know it had a 1/17th HP 100 rpm gearmotor on it before. I want to be able to vary the speed from 0 to max rpms, and was told that DC motors are superior for this application. Simple enough for some, but not for me.
I thought I'd be able to go find a DC motor that had the ac/dc converter built-in, as well as a variable speed dial <grin>. What I've found has been a nightmare.
It seems I can buy a 90V or 130V DC motor (they're all over eBay) and do a "simple" ac to dc conversion using a bridge rectifier and capacitor to smooth the current. Great. The only problem is... I have no idea how to size and/or choose a rectifier or capacitor for such a setup. Electricity in general gives me indigestion. Could someone help me with this step? Is there a better way to do it?
Also, I thought of going with a 12V motor at first because I could supposedly use a washer motor, etc. Besides, 12V is friendly since we all have cars However, finding a speed control for the amps it would draw is difficult (for me). Also, can someone verify this for me... I have NEVER understood this. Let's say my motor will require 600 watts... if my motor is 12V, wouldn't that be a 50 amp current? And if I used a 90V motor, my amps would be 7ish? As a result, would that require much larger wires for the 12V setup, or does the wire size depend *on the wattage*? I have never understood that.
It would be awesome if someone could say "you need this part #, this gauge wire from here to here, from there to there" and so-on, but I don't expect that. I'm actually a very handy guy, but electricity is my achille's heel.
Again, I just want to wire up a motor to the belt so it will run, and have the ability to vary the speed. As this is a tinkering project, I don't want to buy the whiz-bang super motor and control 9000zx. A decent, used eBay motor, (hopefully) wire I have here, and the rest of the controls I"ll need to buy. Speaking of which, how will I choose the variable speed control? Most of them I've seen say things like "12V-48V variable speed control rated at 5 amps" and so-on. To me it seems it would be able to carry more amps at 12v and less at 48...., but again--I just don't do electrical very well!
Sorry for the long post, and thank you so much in advance for any help anyone can send my way!
