there's a bunch of them, but a Teck90, RWU90, NMWU should do. A 3/0 awg will keep you above 5% drop at the 200amp for a service (80% of overcurrent devices minimum still at the 3/0). Pull it as a sub and you'll be up to the 4/0 to maintian a 3% drop. Don't hesitate to call your local inspector for confirmation. Standata can service particular areas with special needs.I would like to have 200 amp service to my new shop 300 feet direct buried
from the power pole.I live in Sask.Canada.
What size and type of wire do I need.
Thanks Barry
PS. 240 volt service
R | Pulse vs wire size | Technical Repair | 6 | |
Wire size for 1.5Hp motor. | General Electronics Chat | 14 | ||
D | Wire size for use with 30A fuse? | General Electronics Chat | 8 | |
Wire size ! | General Electronics Chat | 47 | ||
Is have larger wire size can make circuit braker trip more fast ? | General Electronics Chat | 31 |
by Jeff Child
