The generator uses a "Delco" style housing such as a traditional alternator.A problem with a mechanical brake that may come up is, instead of burning out stator coils you will then start breaking blades. Using permanent magnet generators is a cheap solution but one with a problem with regulation. Because you can't easily regulate the out-put.
Not knowing what type of generator your using, either a radial or axial style, can you tell us? There is a way of regulating that isn't well known but seems to work pretty well called "field regulation". This is where you add a coil around the stator and put a current through it to counter act the current made in the stator. In effect it counter acts the fields of the rotating permanent magnets. Their using it in some PMDC motors for EVs to create 'field weakening' to get more speed from the motor at light load.
