I don't really know what you mean there. pin 2 = ADJ ? how can I know which is which ?Couple of things I'd add. Beware - there are LM317s out there with metal tabs which are internally connected to pin 2.
Note all the way to the bottom of the TI data sheet. They may not be "pin numbers" so to speak, just reference numbers in the data sheets, but most TO-220 package data sheets still use the same ones.The "T" version is irrelevant, you are still talking about TO220 packages.
Not one on the TI version marks pin numbers, mainly because TO220 package don't have pin numbers. It is why I put the packages on my illustrations.
Again, not too sure I understand what you say here. What is the metal tab ? is it the metal part at the top of the component ? Is this not to be mounted onto the heat sink for better cooling ?As far as I know all the metal tabs on a TO220 case are connected to the output pin, this is pretty well universal. I use kapton tape and nylon shoulder washers, or you can buy mounting kits for that package style that have the same parts to keep the metal case isolated from the heat sink.
I'm not sure I would be able to do this correctly and efficiently so I'd rather use and already made transformer and regulator.If you want to build a bit of circuitry I can help you make a switching mode regulator that will reduce the current requirements a lot for the fans.
Probably. The thing to be careful of is pay attention to the fans current rating. Remember, the power supply must exceed the total current rating by a comfortable margin. That and either a power strip or an extension cord with two outlets that can take both transformers. The big advantage is the design work for the power supply has been done.Coming back to my previous post, is it fine to put a second transformer from the mains, for the 12v part of the circuit ? Anything to consider when connecting both transformers to the mains ?
Thread starter | Similar threads | Forum | Replies | Date |
Current and transformers | Power Electronics | 9 | ||
Re-using old transformers | Power Electronics | 16 | ||
P | Transformers and Inductors pricing | Power Electronics | 6 | |
Transformers Question | Power Electronics | 10 | ||
K | Multiple Transformers | General Electronics Chat | 8 |
by Jake Hertz
by Aaron Carman
by Don Wilcher
by Jake Hertz
