pinout Of Q2, followedA different thought occurred, how sure you are you don't have a wiring error? You could take pictures of your circuit (both sides) and give us a complete parts list. I am especially curious about Q2, MOSFETs do not have a standard in pin outs.
No. It should drop around 3-3.3 volts across LED. I was under the impression the voltage source only has to be .7 volts higher than this( for v drop across Rsense)What is the gate voltage? If it's at Vcc, then your LED voltage drop is causing the MOSFET to be fully on. Making R3 smaller will indeed cause current to increase, but the NPN will be off, so you will have no regulation. I doubt that a ≈2 Amp LED exists that will drop only ≈2 to 2.5V, which is what you would need with this supply voltage. Try fewer LEDs, or a higher supply voltage.
Have you measured the gate voltage?No. It should drop around 3-3.3 volts across LED. I was under the impression the voltage source only has to be .7 volts higher than this( for v drop across Rsense)
The problem I find is in practice a smaller R3 does not cause more current. and makes it appear as if Q1 turn on voltage is dropping. Also the voltage to which I read Q1 Vbe is, accurately predicts with the current I measure, via ohms law the sense resistor's actual ohmage.
adding the .1uF cap took the max current I could draw(1.5 amps(with any sense resistor, since Vbe dropped as sense R dropped(in measurment))) to about 1.9 amps max(Vbe dropped, but not as much)
Why I'm a getting a reading on my multimeter that Vbe is so low(i.e. .2v, .3v,.49v..) with different sense resistors?
oscillation of some type?
No oscope hahWhy not take pictures of your breadboard (top and bottom) and post them?
I'm thinking of wiring my own for experimentation. I suspect my setup is a bit better, unless you have an oscope you haven't mentioned?
I would probably use a protoboard like I showed earlier.
Suggestion, replace the LEDs with a current meter or a 5Ω resistor and measure the current through this setup.
Another thought suggested itself. MOSFETs are ESD sensitive (very). It is possible you have a bad component.
Don't you have a voltmeter? You don't need a scope to measure DC.No oscope hah
I did replace the LEDs with an ammeter. //no change
I initially tested the circuit on a bredboard with 2 mosfets(irf510 ad irfs630) They worked at low currents and I went along with the build with the irf510 which had a nice metal backing. I have easily touched it with all sorts of things while building...
Perhaps I should solder in another to test?
This is an analog circuit. It doesn't require the MOSFET to be fully on. Feedback through the NPN forces Vgs to the value that allows the MOSFET to pass current equal to Vbe/R3. At least, that's the theory.\(R__{DS__{(on)}}\) will be 0.54 ohms for IRF510 when \(V__{GS}\) is atleast 10V i.e.. to turn on the mosfet you need 10V at its gate ,your supply voltage is 7.6 increase it.
Good Luck
Just 1 T6 led to power. Would like 2.5 amps on 'high' mode. I have switch that I have that puts more resistors in paralell.What is the part number of your LED?
How many do you have in series?
I have been assuming you had 3 LEDs in series, as in your schematic. Perhaps you mentioned previously that you had only one. If not - your bad!Just 1 T6 led to power. Would like 2.5 amps on 'high' mode. I have switch that I have that puts more resistors in paralell.
I have tested with the led and just an ammeter from vin to drain. I will test with just the ammeter with current setup again.
sorry, I dont know if I did.I have been assuming you had 3 LEDs in series, as in your schematic. Perhaps you mentioned previously that you had only one. If not - your bad!
by Jake Hertz
by Robert Keim
by Jake Hertz
by Jake Hertz
