need 8 cells
but why to use 3 parallel on either side and 2 series in middle ?
Sir,hi k6,
Welcome to AAC,
I think you are mis-reading the diagram, they are all in series, the two centre batteries are drawn in a simpler way.
Consider the two 2.1V cells in parallel, what would the voltage be.?
E
Sir, this a thermal battery.hi,
As this is homework, I can only give you hints not the final answer.
A question for you, if you built a battery in that configuration, using those cells, which all had the same specification, ie: voltage and A-hr capacity, what would be the design flaw.??
E
Sir,You say that you need 8 cells but your schematic shows 14 cells. How was the question worded when it was given to you ?
Les.
Why do you want them in parallel?So why we are using three parallel combinations
May be for heat generatingWhy do you want them in parallel?
That makes no sense.May be for heat generating
Hmm.Don't hold your breath .Would love to see the actual homework/project question.
yes, it's one shot batteryThat makes no sense.
You say it's a thermal battery.
Does that mean it's a one-shot type of battery that only operates for a short time once it's energized?
