Why LED is not turning OFF - 8051 Timers
Djsarakar
Joined Jul 26, 2020
317
. One possible solution for debounce timer routine is setting a timer for 1 ms period and activate timing by loading a countdown variable.
It will be very difficult for me to draw a complete state diagram right now. That's why I will try to make one step at one time
Timer interrupt is set for 1ms and debounce time is 20 ms. When timer interrupt happen we check button is pressed so if button is pressed we decrement count
So when counter will reach at zero. State will change
trebla
Joined Jun 29, 2019
209
Debounce timer does not check the button state. It starts for button press when:
a) if debounce state is "button acknowledged"
and
b) if the countdown variable value is above zero (in C: if(a&&b) ).
After starting it changes debounce state to "button press debounce active". It is necessary for avoiding button press acnowledging again constantly.
It checks only timer interrupt flag and countdown variable value.
If countdown value reaches zero then it changes debounce state to "button press debounced" and ends.
For button release debouncing we can use same timer routine but debounce state values are different as descibed in #178.
For this debounce timer you can also draw state diagram, i think there are 4 states at first glance.
In state diagram a circle means system state (for example "button press debounce active") and arrow between states means a condition for changing to another state (for example "countdown_variable == 0").
Djsarakar
Joined Jul 26, 2020
317
Okay I think state diagram should start from ideal state, what happen in ideal state? In ideal state button is not pressed. So when button press and count down is greater then zero we are in button pressed acknowledge state. So when count down reach to zero button press acknowledge state change to button press debounce active state
trebla
Joined Jun 29, 2019
209
Ideal state for debounce timer is "timer_idle" and it checks for debounce status. When debounce status goes to "button acknowledged" then it moves to another state which is "button press debounce active" and there will be checked the countdown_variable". If the countdown_variable goes down to zero then the last state is "button press debounced" where this timer routine ends.
Djsarakar
Joined Jul 26, 2020
317
My understanding is Interrupt happens at every 1ms interval. When switch button is pressed, count up interrupt and if the count reach upto 40 counts (40ms) it means switch button has stopped its bouncing and then control LED
If switch button is released, count down interrupt and When it reaches zero, it means button is released
My problem is that I am not able to create a state diagram Even after explaining it many times by @trebla
Would this approach be okay if I would look at the sample code and try to make state diagrams for them? Maybe I will get ideas from this how do you decide how many states will be and what will be the present state, what will be the next state
I am thinking this because I think if my current approach is not working I must change my approach
trebla
Joined Jun 29, 2019
209
There are two example functions to call frequently in main loop for debouncing:
C:
void ButtonCheck(void) { //check button status
    if(debounce_state == IDLE) {  //not pressed before
        if(BUTTON == PRESSED) {  //button press acknowledge
            debounce_state = BUTTON_PRESS_ACK; //change debounce status
    else if(debounce_state == PRESS_DEBOUNCED) {  //button press debounce timer ended
        if(BUTTON == NOT_PRESSED) {  //button release acknowledged
            debounce_state = BUTTON_RELEASE_ACK; //change debounce status
            debounce_delay = DELAY_20ms;  //reload debounce timer value
} //void ButtonCheck(void)
void DebounceTimer(void) {  //delay for button debounce, software polling
    static unsigned int debounce_delay;
    if(Timer_IF) {  //check timer interrupt flag
        Timer_IF = 0; //clear flag
        if(debounce_state == BUTTON_PRESS_ACK) {  //button press acknowledged
            debounce_state = PRESS_DEBOUNCE_ACT;  //change debounce status to active
        } //button press acknowledged
        if(debounce_state == PRESS_DEBOUNCE_ACT) {  //we must count down
            if(debounce_delay > 0) {  //until counter is zero
                debounce_delay--;  //variable decrement
            else {
                debounce_state = PRESS_DEBOUNCED;  //change debounce status to debounced
        } //press debounce count down
        if(debounce_state = BUTTON_RELEASE_ACK) {  //button release acknowledged
            debounce_state = RELEASE_DEBOUNCE_ACT;  //change debounce status to active
        } //button release acknowledged
        if(debounce_state == RELEASE_DEBOUNCE_ACT) {  //we must count down
            else {
                debounce_state = IDLE;  //change debounce status to idle
        } //release debounce count down
    } //check timer interrupt flag
} //void DebounceTimer(void)
