A typical LVDT output is below. As you can see, outside the range the output falls off.
A reason I have seen given for this is that it recieves less flux from the primary, as per this next picture
However is it not also true that for a transformer, the output determined by the ratio of primary to secondary turns, now in this case, the primary turns are decreasing so should the output not increase?
I've clearly got something wrong, so clarification would be wonderful!
