Which load is good to use to fast rising and falling edges of PWM signal?.
pinkyponky
Joined Nov 28, 2019
338
This is general question..
Please could you answer me that which load to be used to fast switching of falling and rising edges of PWM signal and WHY?
Thank you.
LowQCab
Joined Nov 6, 2012
3,568
Please get help with your English translation,
your question does not make any sense.
You have a PWM "Signal",
what generates this Signal ?,
and what is it intended to control ?
BobTPH
Joined Jun 5, 2013
8,073
I think you have things backwards, you don’t design a circuit and then ask what load it would be good for. You design the circuit for the load it is intended for.
Bob
16,493
If the intentis to check a PWM circuit for correct function then the load should probably be resistive, similar in resistance to the loading of the actual circuit that it is intended to drive,
