This is an interesting quantum view of electricity flowActually the "effect" of electron movement is near the speed of light, but the electron movement is much slower. Since all of the electrons essentially move together along the series circuit, like boxcars on a train, all of the bulb filaments are exposed to the movement of electrons at the same time.
http://amasci.com/miscon/speed.html
Ken
WOW! The reference you sited above (paragraph near the end about the salt crystal) sure changed my perception. I was thinking more along the lines of hydraulics with a non compressible fluid and having instantaneous equal flow at any point along the circuit. Your train analogy sure seems to be a good fit with the slack in the couplings allowing each car to move a slight distance before the next car moves.
I second that answer. I believe I saw this in an MIT opencourseware lecture video on circuits.Actually the "effect" of electron movement is near the speed of light, but the electron movement is much slower. Since all of the electrons essentially move together along the series circuit, like boxcars on a train, all of the bulb filaments are exposed to the movement of electrons at the same time.
Ken
They are in series, so the hotter one starves others of voltage....so the answer is - the bulb that has the highest cold filament resistance will likely light up first - because it will begin to dissipate the most power first, thus increasing the filament resistance more, thus beginning to starve the others of current. Of course, this assumes that all the filaments have the same thermal time constants, etc...
