I felt that operation characteristics is enough to design circuits using FET.
I'll be thankful if someone can clarify.
You didn't need to know about the inner solid-state workings of a FET to design circuits with them.I felt that operation characteristics is enough to design circuits using FET.
Thanks..You didn't need to know about the inner solid-state workings of a FET to design circuits with them.
You just need to understand it from a functional point-0f-view and understand everything on the data sheet.
At what level are you going to design. Simple discrete components circuits? No just a basic understanding is needed. Designing new FETs or chips using FETs ? Yes, in great detail.I felt that operation characteristics is enough to design circuits using FET.
Thanks. Right now I'm only designing circuits in which I'm using FETs only as a switch most of the times.At what level are you going to design. Simple discrete components circuits? No just a basic understanding is needed. Designing new FETs or chips using FETs ? Yes, in great detail.
Is this an engineering course or a technician course? Either answer can be correct.
Only a basic understanding is needed. Engineers and teachers might have a different opinion.Thanks. Right now I'm only designing circuits in which I'm using FETs only as a switch most of the times.
