Perfect. Thank you SO much. I’ll let you know how it goes. Much appreciated.I'm sorry. We are just not communicarting. The dashed line was explanatory, not a connection.
Let me draw out the whole thing for you. (Please excuse the rush job)
When you say adapters, I'm not sure what adapters. Also, I need the electricity from the PIR to be AC. The relay enables me to do that. I'm open to ideas, however. LMK12V AC PIR is not available. You can use adapters to achieve your desired voltage level to run the PIR.
I don't think he read much of the thread before commenting. Using a plug-in power supply was mentioned early on. It would require mains voltage, it isn't appropriate.When you say adapters, I'm not sure what adapters. Also, I need the electricity from the PIR to be AC. The relay enables me to do that. I'm open to ideas, however. LMK
by Jeff Child
by Jake Hertz
by Duane Benson
