That would be MacWayneh to you, buster...Who are you? Macgyver?
Seriously now. I just browsed through the manual, and it's the first time I've heard of "Hydro-generated ignition" ... fascinating stuff...
Yeah... but how does it exactly work? Is it really a turbine? ... if it is, it's probably recharging a battery. Which wouldn't surprise me, since there are old calculators out there that work using solar cells that can work indoors!Well I am glad it exists because it means I will still have hot water in a power failure.
This is a feature to look for if I ever replace it.
My guess it is a supercap and not a battery.Yeah... but how does it exactly work? Is it really a turbine? ... if it is, it's probably recharging a battery. Which wouldn't surprise me, since there are old calculators out there that work using solar cells that can work indoors!
But in this case, the thing is supposed to be driving an igniter that produces a spark... that's much more power than calculator's!
I can't take credit for anything except finding a guy that knew the solution and was willing to share it with me. I would have installed a new one long before figuring out that fix.Who are you? Macgyver?
That makes me feel privileged. I grew up around Kentucky Engineering and learned to appreciate that some of the simplest fixes had a primitive sort of beauty...and then there were the complete botch jobs. I still carry clothes pins in my tool box because there are so many ways you can use them.I can't take credit for anything except finding a guy that knew the solution and was willing to share it with me. I would have installed a new one long before figuring out that fix.
The manual shows a turbine and says it should generate at least 1.6V AC with a water flow-rate of at least 0.5 gal per min.but how does it exactly work? Is it really a turbine?
from first page...Could your indicator light be produced by the Flame?
There is no pilot light.
Fish bowl.from first page...
from first page...
Fish bowl.
I have the a above referenced Bosch Tankless hot water heater. Could your indicator light be produced by the Flame? I clean my heater exchanger once a year to remove any carbon build up. If you notice white dust below the unit I would clean the heat exchanger.
Not sure what that means! But he did state that it only lights when water is used. My Bosch tankless water heater has a small glass window. The pilot light is only visible at an angle and the small window lights up when the flame is producing hot water.Fish bowl.
Goldfish have a memory of about 7 seconds - my estimate of the time it takes them to circle the fish bowl (unless they are in one of those panic modes where they circle the bowl about 7 times in one second!).And I am not even sure I completely understood your fish bowl comment but it was funny all the same.
I have a fairly large house, and we have to run quite a bit of water to get the master shower warm in the mornings. I've thought about installing a tankless at that end of the house. A small electric unit (60 amp) might suffice and would be easier to install than a gas one. It would just run the low-flow shower and the sinks. I'll have to do some more research on my options. I need to make the final choice between gas and electricity
Here's a page https://www.newtanklesswaterheaters.com/water-heaters-electric-vs-gas-know-pros-cons/ I ran across recently. I won't vouch for his opinions but it's interesting reading. Short form: he doesn't like them.
The part in this Thread was how do they ignite gas in the OP's Thread about his Tankless Hot Water Heater. We found out that during a power outage there is no need to worry about hot water because the waters flow will generate the voltage to ignite the gas which was pointed out by the OP was good to have his type of water heater. I will agree with @BR-549 I would go with gas.I have a fairly large house, and we have to run quite a bit of water to get the master shower warm in the mornings. I've thought about installing a tankless at that end of the house. A small electric unit (60 amp) might suffice and would be easier to install than a gas one. It would just run the low-flow shower and the sinks. I'll have to do some more research on my options. I need to make the final choice between gas and electricity
by Jake Hertz
by Jake Hertz
by Duane Benson
by Duane Benson
