where can I find a 5 Volt solenoid
And123
Joined Mar 8, 2009
4
I'm currently building a project for an electronics class, I need a 5 Volt solenoid that is to run off of a TTL PLC board.
Where can I find a 5volt linear solenoid for a reasonable cost and where can I find one with as long as a shaft as possible?
Thanks...
SgtWookie
Joined Jul 17, 2007
22,230
Solenoids are getting to be hard to find, particularly for low voltages.
What is it that you are attempting to accomplish?
How long of a stroke do you need?
Pushing or pulling?
"Ding-dong" doorbells from the 50's through the late 70's had a pair of 24VAC solenoids in them; a single "ding" for the rear door, and dual-tone for the front. They had a fairly long throw. You could use a relay to switch power to the solenoid. A 24vac solenoid will operate on 17v-18v DC.
And123
Joined Mar 8, 2009
4
Appreciate it guys, I ended up with a 24 VDC solenoid. This is to actuate a starting gate for a pinewood derby racetrack.
