What's the longest rotational word in the English language.
cmartinez
Joined Jan 17, 2007
7,290
God that was hard... at least for me. But here it goes:
SLIME -> LIMES
Kind of lame, considering there's only one degree of rotation ... but what the heck.
jpanhalt
Joined Jan 18, 2008
11,088
Here's a couple...
tattarrattat => tattarrattat
palindromes => semordnilap
The first example is a palindrome. The second involves inversion of the word, but the words are not different, so it is a semordnilap, not a palindrome. (edited)
A rotate keeps the same order of letters for those that are rotated. It is not reading the word backwards. For example:
"abcdefgh" rotated right last letter to first letter x 4 gives: "efghabcd." It is like the "swapf" PIC instruction.
Here's some enhanced midrange code that does the same:
Code:
     movlw     b'10000001'    ;WREG = b'10000001
     bsf       STATUS,0
     btfss     WREG,0
     bcf       STATUS,0
     rrf       WREG
     bra       $-4            ;after 4 rotations WREG = b'00011000'
     nop
;alternatively
     swapf     WREG
     nop                      ;WREG = b'00011000'
I
joeyd999
Joined Jun 6, 2011
4,477
Here is my first cut (on Ubuntu Linux). The resulting .txt file is attached.
Bash:
#!/bin/bash
DICT=/usr/share/dict/words
TEMP=tempfile
OUT=outfile.txt
#Clean start -- delete old temporary and output files
rm -f $TEMP $OUT
#Iterate over each word in the dictionary file
cat $DICT | while read WORD || [[ -n $WORD ]]; do
    LENGTH=${#WORD}       #get word length
    if (( LENGTH > 1 )); then   #we only need to check words.length > 1
        #Construct a regexp to compare all permutations simultaneously
        #i.e. "joeyd" => "^(oeydj|eydjo|ydjoe|djoey)$"
        REGEX="^("
        for ((i=1 ; i < LENGTH; i++)); do
            if ((i>1)); then
                REGEX=${REGEX}\|${WORD:$i}${WORD:0:((i))}
            else
                REGEX=${REGEX}${WORD:$i}${WORD:0:((i))}
            fi
        done
        REGEX="${REGEX})$"  #close the regexp
        unset MATCHLIST
        for MATCH in `grep -iE $REGEX $DICT`; do
            MATCHLIST="$MATCHLIST $MATCH"
        done
        if [[ -v MATCHLIST ]]; then
            echo "$LENGTH $WORD $MATCHLIST"
            echo "$LENGTH $WORD $MATCHLIST" >> $TEMP
        fi
    fi
done
sort -n $TEMP > $OUT
I think I can modify it to both eliminate duplicates and make it more efficient. Maybe later.
Edit: I should point out that the dictionary contains many words with punctuation (i.e. apostrophes, mostly). I'm wondering if there'd be additional unique results if I removed punctuation during the search.
Edit 2: Modified the code. I had the final sort out of place. It was sorting every iteration. Not good.
ericgibbs
Joined Jan 29, 2010
12,258
hi,
Given a strong pull and a stretch of the imagination then 'elastic >> citsale' , which a berry, could be the longest word.!:rolleyes:
E
joeyd999
Joined Jun 6, 2011
4,477
hi,
E
The longest words from my exhaustive dictionary search are:
elections selection
electives selective
housework workhouse
printings sprinting
joeyd999
Joined Jun 6, 2011
4,477
Now that I graciously provided a huge dictionary of "rotatable" words, how about a poetry competition using only those words?
Rose hoes shit; hits Eros' shoe...
joeyd999
Joined Jun 6, 2011
4,477
This version creates a list without duplicates. Still not very efficient. Output attached.
Bash:
#!/bin/bash
TEMP=tempfile
OUT=outfile.txt
rm -f $TEMP $OUT
touch $TEMP #avoid file not found error during dup check
        if (! grep -iwq $WORD $TEMP); then  #only process if word does not exist in $TEMP file
            REGEX="^("
                if ((i>1)); then
                else
                fi
            done
            unset MATCHLIST
            done
            fi
        fi
     fi
done
joeyd999
Joined Jun 6, 2011
4,477
I found a more extensive list of words at:
https://github.com/dwyl/english-words
It contains a lot of abbreviations with interspersed periods -- this mucks up my regexp (each . acts like a wild card). So I modified to code to ignore words with periods (below).
I am running the program now...this may take a while. (Hey, @nsaspook, run this on one of your multiprocess server boxes...tell me how fast it runs.)
For now, here is the updated code:
Bash:
#!/bin/bash
#DICT=/usr/share/dict/words
DICT=words.txt
TEMP=tempfile
OUT=outfile.txt
rm -f $TEMP $OUT
    if [[ $WORD != *.* ]]; then   #words with periods (i.e. abbreviations) muck up our regexp
        if ((LENGTH > 1 )); then   #we only need to check words.length > 1
                REGEX="^("
                    if ((i>1)); then
                    else
                    fi
                done
                unset MATCHLIST
                done
                fi
            fi
        fi
    fi
done
joeyd999
Joined Jun 6, 2011
4,477
Lots of acronyms, proper nouns, and (IMO nonsense words), but attached is my final answer.
Processing time, about 1.5 hours. While watching the output, I realized I can speed this up considerably, and, simultaneously eliminate matches such as "weewee".
BTW,
EXPLOITATIONS > SEXPLOITATION
You were correct!
Here are the longest words:
11 anarthropod arthropodan
11 decimosexto sextodecimo
11 deviscerate eviscerated
11 ethological lethologica
11 grasshopper hoppergrass
11 housemother motherhouse
11 peculations speculation
11 stabulation tabulations
12 breakweather weatherbreak
12 great-great- great-great- (say what?)
12 manslaughter slaughterman
13 exploitations sexploitation
joeyd999
Joined Jun 6, 2011
4,477
BTW,
You were correct!
Hey, can we, for fun (and lack of a better word) call these "rotodromes"?
jpanhalt
Joined Jan 18, 2008
11,088
And the winner seems to be #13 with 13 characters (see post #19).
The TS has already disqualified compound words like housework > workhouse.
joeyd999
Joined Jun 6, 2011
4,477
Yes, and words like "weewee".
I can eliminate the weewees, but I have no idea how to instruct the script to eliminate compound words -- without an additional compound word dictionary, and a substantially more complicated search.
jpanhalt
Joined Jan 18, 2008
11,088
I did a semi-manual search for words beginning in "s". Of course, "sledgehammer" came up. "Ledgehammers" could be a real word, but I considered it fabricated, as are a lot of words on such scrabble sites. Derivatives of "slaughter" and "laughters" (e.g., slaughtering and laughterings) came up too.
One could search for all words beginning in "s" and compare that to words of the same length ending in "s." In the spirit of this challenge, however, maybe a minimum of 2 rotations should be required for words beginning "s."
As for weewee and the like, there are lots of very large names for organisms that duplicate a part (called tautonyms). Since such word games often ignore spacing (Martin Gardner and others). One would need to add that as another criterion.
joeyd999
Joined Jun 6, 2011
4,477
I disagree. This'd eliminate clearly different words like:
suprising uprisings
Please see my list. Lots like this.
jpanhalt
Joined Jan 18, 2008
11,088
Palindrome's etymology is from again ("palin") + running back ("drome"). Maybe "rotopalin" or rotapalin" or "rotopalindrome." (Unfortunately those mix Latin and Greek.) I was thinking of "rotonyms," but apparently that word is taken and applies to a type of encrypting (http://tyleruebele.com/rotonym ). From the movie 2001 Space Odyssey) , "HAL" was IBM with each letter shifted left in the standard alphabet.
