What's the function of the following diode in the diagram?
JosXD
Joined Mar 16, 2022
63
The diode is in the first arrow, it is reverse polarity protection?, if yes, shouldn't be placed in the second arrow?
21,225
It is how a boost converter works. The diode blocks the voltage on COUT from returning to the Lithium Cell so it continues to build up when the switch is open, and the inductor charges the capacitor. When the switch is closed, the capacitor can only discharge into the load. This process repeats each switching cycle.
You didn't say which part you were using in your example. The steady state behavior may be different from the transient behavior.
JosXD
Joined Mar 16, 2022
63
Hi Papabravo, is the SD6201 Boost Converter, datasheet: https://datasheet.lcsc.com/lcsc/1804250821_SHOUDING-SD6201-AF_C171633.pdf
In the Datasheet, you can see that the first diagram says typical aplication circuit and in that diagram there is not diode and also there is not path between Vout and Inductor SW.
So my question, is the diode in the first arrow for reverse polarity protection or what is it for?
34,427
I believe that data sheet figure is in error and the diode should be there, since it is shown in two other circuit examples.
michael8
Joined Jan 11, 2015
414
Interesting. I notice that there isn't any block diagram of what's inside the IC.
The datasheet mentions both an NMOS switch and a PMOS switch.
page 7: VOUT (Pin 5): Output Voltage Sense Input and Drain of the Internal Synchronous Rectifier MOSFET.
Also:
VIN (Pin 6): Battery Input Voltage. The device gets its start-up bias from VIN. Once VOUT exceeds VIN,
bias comes from VOUT. Thus, once started, operation is completely independent from VIN.
A guess: Perhaps the diode is to get voltage to the output (which runs the chip!) for startup under certain
input voltage conditions?
21,225
If the part is indeed a synchronous boost regulator, then operation without the diode is possible. In such a regulator it is not uncommon to add a diode in parallel with the synchronous switch and its associated body diode. Nothing wrong with that at all.
k1ng 1337
Joined Sep 11, 2020
960
Why add a diode if the FETs do the work?
JosXD
Joined Mar 16, 2022
63
So guys, then this SD6201 has that diode bypassed like when you add reverse current protection to a LDO?
also because is a synchronous boost converter and uses like an internal p mos? here is the SX1308 which doesn't have a pin for Vout, the Vout goes directly from the inductor:
SX1308 datasheet: https://datasheetspdf.com/pdf-file/921054/Suosemi/SX1308/1
boostbuck
Joined Oct 5, 2017
514
It appears from the second paragraph in the datasheet that the SD6201 is able to run at low output voltages without an external shottky bypass diode.
34,427
So the diode is apparently needed only for an output greater than 4.3V.
It's not clear to me how the diode helps raise the output voltage.
21,225
It is possible that with the external diode you have more range on the possible duty cycle values. Since the output voltage is inversely proportional to (1-D), a larger duty cycle results in a larger boost ratio. Without some kind of an internal block diagram or a simulation model it will be hard to tell for certain.
