Some BNC dummy loads/terminations are exactly that.What would be the consequences of this and why?
Thanks
S11 measurement of a 1/2 watt BNC teminator from 300 Khz to 3 Ghz. Marker 2, S11= -9.5 db or a swr of 2:1Some BNC dummy loads/terminations are exactly that.
It has to be a non inductive resistor like carbon composition, and there's no good way to hang a wire ended component on the end of coax without some hint of mis match.
The top quality ones are an annular ring of carbon pressed into an end cap, the hole in the middle accommodates the centre pin.
